1 - 15 of 15 Posts
Has anyone else had a problem with this. my tank has started leaking at the rear seem. where it pivots on the frame. im getting it rewelded but i was wondering if anyone else had this issue?
Captain Obvious
Lots of documented cases... especially on the SP1's.
Dr. Carbon
I recently realized the leak aswell, I have a 00. let me know how the weld job goes, and take pics of the welded unit please.
Discussion Starter #6
i was going to take it by a dealer. i know honda is pretty good if you bitch to them a lot theyll replace things like this under goodwill but i havent had time to go by a dealer.
also i dont own a camera so i cant help with pics of the weld job
Tank sealer,It worked on our 35 chevy pickup.Just clean tank out,take out fuel pump,put it in,shake it around,let dry,and put it back together.
I've used the JB weld and it only held for 6 months or so. I've also had the seams welded. It still leaked. I ended up using gas tank sealer. The 2 part stuff you can get at the parts store. I basically looks like JB weld but is specifically made for gas tank leaks.
Discussion Starter #9
is the gas tank sealer your taking about go one the outside of the tank? or is it like kreem coat that goes on the inside of the tank
Inside of the tank.You might be able to get it from a place that deals with old car resto's.Like Year one and so on.
The stuff I was talking about went on the outside of the tank, around the rear mount.
1 - 15 of 15 Posts
