Gents,
After not being able to ride the rc51 all freaking season due to multiple issues w/the gas tank needing to be fixed, she is at last ready to ride.
Before i sent the tank out to be fixed, i drained all the gas by allowing the engine to run it dry. i then turned on/off the master switch to make sure as much fuel was pushed out etc. and then shipped the tank off to be fixed/painted.
So when i took the tank off no issues.
I now got the tank back, hooked up all hoses and the fuel pump wire and nothing? I turn the key, everything lights up like normal. I flip the master switch on the right clip on and i hear a click in the rear tail section area, see the pc3 light up and do its thing and resonds to throttle inputs, but the fuel pump does NOT do its normal primping sound.
There is a 1/2 of tank of fresh fuel and the bike will turn over but obviously not fire up.
Thoughts?
I have gone through all the fuses i can find, looked at the service manual but that didn't seem to help much. The only fuel pump like fuse i can find is the 25 amp PGI fuse in the tail.
Again, before i sent the tank off no issues, all worked. Now the fuel pump won't prime?
Thoughts?
