As per the title,
im parting out a 2001 748RS that I bought as a project to restore, but have now changed my plans.
It was originally supplied by John Hackett here in the UK. I believe it was raced for a season in British Supersport, but other than that I have no more info on it's history. The frame has a proper chassis number and it is a genuine bike.
The pair of engines were both rebuilt and have not been used since their rebuilds. This was around 7 years ago.
The parts are located in the UK and i'll ship anywhere.
Prices are in GBP pounds - paypal payment is fine if you add on 4% to cover fees.
If you have any questions feel free to message me by PM, or preferably email:
tomirvine1 (at) mac (dot) com
Parts, prices and photos as follows:
1. £1400 748RS engine 2001 – rebuilt some years ago by BSB mechanic Alan Shirley, and just stored and not run since. Includes starter motor and 54mm inlet manifolds, mil-spec engine pick up, corsa cank case breather, EVR/STM camshaft pulleys.
2. £1400 748RS second engine – as above but without mil-spec engine pick up or EVR pulleys.
3. £200 748RS rear subframe. Genuine RS subframe with threaded inserts for the carbon seat support bracket. Good condition – just a slight dent in the rear upright.
4. £250 748RS MS Production carbon underseat breather. Damaged and repaired. Fully functional
5. £300 748RS / 748R carbon airbox (complete). Very good condition, includes the set of 4 screws for mounting the lower section to the cylinder heads.
6. £500 748RS 54mm throttle bodies. Complete with original RS fuel lines and mil-spec injector wiring harness.
7. £100 748RS carbon front mudguard. Very good condition.
8. £250 748RS carbon front fairing support. Damaged and repaired – quite rough but the repair is strong. Very rare part.
9. £500 748RS pair of Marchesini alloy wheels. The lightest of all the aluminium 5-spoke wheels – the front spokes are slimmer than the standard alloy 5-spokes. Also fitted to the 998R road bike. Good condition – just some chips and marks in the paint. Totally straight.
10. £40 Pair of left and right-hand clip-ons & bars. Later 2-bolt type. Very good condition apart from a scrape on the right hand bar end.
11. £220 Ohlins steering damper with RS billet alloy mounting clamp. Very good condition.
12. £140 Brembo forged radial front brake master cylinder & lever 19x20 ratio. Very good condition – just a small scuff on the body.
13. £80 748RS corsa regulator/rectifier. Has a few broken heat sink ribs on the body.
14. £45 Brembo OEM clutch master cylinder & lever. Very good condition apart from a small scuff on the end of the lever.
15. £120 748RS idle adjuster cable & mounting bracket.
16. £10 748RS throttle cable. Good condition
17. £280 748RS / 996RS MS Production fluid reservoir. Very good condition.
18. £35 Rear suspension rocker & bolts. Very good condition
19. £45 748RS carbon chain guard. Good condition – has a little damage from rubbing against the rear wheel.
20. £130 748RS complete set of yokes & steering eccentric. Good condition – some wear on the lock-stops
21. £180 Pair of Brembo P4/34 front brake callipers (65mm mount) with set of good used pads. Very good condition.
22. £40 Brembo goldline rear brake calliper with good set of used pads. Very good used condition.
23. £600 748RS mil-spec wiring harness with ECU & Power Commander III. Good working condition but could do with a bit of cosmetic improvement.
24. £600 748RS Magneti Marelli MT300 digital dashboard. Includes original carbon mounting plate. Very good condition.
25. £250 748RS fuel pump with mil-spec wiring and up-rated stainless steel CRC fuel connectors
26. £140 Swingarm with eccentric hub and calliper hanger, Good condition apart from a scrape on the side and a few marks here and there.
27. £675 Ohlins RS rear shock. Very good condition – just some wear on the pre-load adjuster.
28. £350 748RS pair of Termignoni 54mm bore end cans. Titanium sleeves. 425mm long, 135mm diameter. Genuine RS cans. Includes straps & hangers. Good overall condition but there a some dents as shown in the photos.
29. £900 748RS full 54mm corsa race exhaust system. There are a couple of dents in the pipework, and a scrape on the right hand can, but the system is generally in very good condition. Very rare exhaust system - perfect also for use with tuned 996 engines.
30. £150 MS Production carbon RS battery holder – brand new – never fitted.
31. £900 748 RS race frame – 2001. Genuine RS race frame with chassis number. One of only 42 produced in 2001. Lightest of all the Ducati 748 – 996 frames (even lighter than the 996RS & 998RS frames), as it was made of a different gauge of tubing to save weight. The frame has the lowest cross brace to allow for the fitting of the extra large airbox. Very rare! The front lock stop has been removed but if required I will supply the frame with a replacement lockstop from another frame.
32. £800 748RS Ohlins race forks. They are marked as FG8500 but have full WSS-spec race internals and fork seals. Some cosmetic damage but nothing serious. Very rare!
33. £120 748RS MS Production carbon/Kevlar swingarm guard. Some scratches but otherwise very good condition.
34. £320 748RS Brembo fully floating race discs. Ultra-rare. Proper WSS-spec race discs. 6mm thick floating rotors with billet carriers. 12mm offset, so can also be fitted to the 998R & 996R road bikes. Very good condition – hardly worn at all.
