1 - 15 of 15 Posts
As per the title, i'm clearing out quite a few race parts.
They're mostly 996RS & Factory, but there are also some 998 and 748 race parts in there too.
I've uploaded a lot of photos to this link:
http://s807.photobucket.com/albums/yy357/tom_998R/Corsa race parts for sale/?start=all
and i'll post a few pics further down the posting to give a flavour of what's available.
I'm building a 998RS so i'd also be interested in anything 998RS you might want to trade :)
The parts are located in the UK and priced in GBP. I'll ship internationally and paypal payment is fine if you include the 4% charge.
Any questions just PM or email me at
tomirvine1 (at) mac.com
003 £575 Ohlins DU7293 corsa race shock for RS swingarm
004 £525 998RS/996RS complete rear axle & disc
005 £450 998RS/999RS 4-pillar slipper clutch complete
006 £300 996RS/998RS large axle magnesium hub with bearings
007 £375 996/998 Factrory billet suspension rocker
008 £700 996RS Close ratio gearbox
009 £150 996RS layshaft & timing gears
010 £250 RS corsa gear selectors
011 £150 996RS magnesium oil pick up
012 £600 2001 996RS pair of Marchesini 16.5” magnesium race wheels
013 £900 2000 996RS polished crank & Pankl titanium rods ex-Neil Hodgson GSE 20mm gudgeon pin size
014 £35 996RS internal oil filter
015 £60 996RS oil pump
016 £200 996RS/916R/916 Racing belt rollers & mounting plates
017 £150 996RS magnesium oil pick up
018 £60 996RS oil pump
019 £100 996RS primary drive gear
020 £120 996RS primary drive gear & crank gear
021 £120 996RS vented clutch cover
022 £200 set of 4 996RS cam inspection covers
023 £200 916R/996RS alternator, flywheel & timing plate
024 £100 RS oil pump (new)
025 £900 pair of 996RS corse heads a pair of matched gas-flowed corsa inlet manifolds and a set of titanium 39mm inlet valves in near new condition. Valve size: 39mm inlet/32mm exhaust - cleaned and refreshed, no cams or exhaust valves, but does include corse belt pulley supports and corse rockers (generally very good, although a couple of rockers are showing a bit of wear)
026 £700 complete set of 996RS cams 450 inlet / G exhaust. VG condition
027 £600 pair of 996RS Pankl titanium conrods (20mm gudgeon pin) with pistons
028 £600 pair of matched Factory 996 crankcases with bolt-on magnesium sump and starter motor blanking plate
029 £1500 pair of Factory 996 heads and matched inlet manifolds. Valve size: 39mm / 32mm with Factory 474 inlet and G exhaust cams.
030 £700 set of 996RS cams 450 inlet / G exhaust
031 £250 set of 996RS cam caps/rollers
032 £700 RS Close ratio gearbox
033 £450 pair of matched 996RS crankcases ex-GSE
034 £450 996RS crank – good condition
035 £200 2001 996RS carbon v-piece original unused part from team GSE Racing
036 £225 996RS lower carbon fluid reservoir
037 £675 996RS / 998RS pair of 17” magnesium Marchesini wide-track race wheels (front 3.5 x 17 / rear 6 x 17)
038 £1800 996RS 60mm twin injector throttle bodies
039 £625 996RS/998RS Ohlins DU1430 race shock
040 £200 998F01 type Factory oil cooler
041 £2500 Verlicchi 996 Factory tig-welded race frame ex-Fogarty/Chili (frame dated August 1998 – Kyalami type with the lower cross brace to allow the largest airbox) purchased directly from Ducati Corse with receipt
042 £1000 MS Production carbon corsa fuel tank 1997/1998
043 £600 996RS heads with valves, rockers & manifolds. Valve size: 39mm / 32mm
044 £140 MS Production l/h carbon airtube – new
045 £140 996RS/998RS pair of new carbon fairing supports LH & RH
046 £300 998F02 alternator, flywheel & timing plate
047 £400 998F02 104mm pistons & barrels
048 £200 998F02 gear selector & forks
049 £350 996RS Pankl titanium conrods
050 £900 Magneti Marelli MR600 race ECU & corsa mil-spec harness custom-made for 996RS with twin injector 60mm throttle bodies
051 £450 748RS throttle bodies, complete with mil-spec injector harness
052 £150 748RS fuel pump sender (new)
053 £500 748RS (MY2000) mil-spec wiring harness & ECU
054 £300 748RS “OE” exhaust cams
055 £220 Pair of Brembo corsa race discs – minimal wear - 3 sets available
056 £120 996RS large oil cooler
057 £2800 996RS complete engine. Running with 431/G cams. Valve size: 39mm / 32mm
Built by Jeff Green of G-Tech Performance. Many photographs available of the engine as it was built up. Excellent condition - very little use since the build. Has a starter motor fitted.
rs
Hello, are all the parts still for sale? I was interested inthe engine, wiring and trottle bodies. Can you confirm if these parts are still there?
Thx, kind regards
Fred from Holland
Or can you please send me a pm whit the specs and prices?
Hi Fred,
I sent you a PM.
Tom.
ducati 996rs crankcases
hello tomi
do you still have a pair of 996rs crankcases
and willing to ship to the netherlands
have a nice day
Hi Tom,
Very nice parts. Which of them are still for sale? What are the prices? Do you have them listed on eBay/where?
Thanks.
Best regards,
Paco
Hi Tom,
Thanks.
Best regards,
Paco
Hi Paco,
sorry for the slow reply but I only just saw your post. Some of these parts are still available - some are sold, but I also have many more new RS/corse parts to add to this list. I've sent you a PM.
Regards,
Tom.
Quack for Ducs
Tom,
Any chance that you might still have the the 998 oversized oil cooler? Also looking for larger air box, underseat oil catch, and Carbon air runners....all for a 998.
Cheers,
Matt
1 - 15 of 15 Posts
