1 - 2 of 2 Posts
Not a converted bike. Not a SMR (racebike) or an SXC (dualsport). . .. An actual 625 street, supermotard. If you are reading this ad, you already know this isnt another 30hp supermoto. . . and you know this isnt just another KTM. This is the rare of the rare on both fronts. The 2005 and 2006 KTM625SMC's, are in most peoples opinion the holy grail of supermoto. The closest thing to a "race bike" but also sound enough, that you're not treating it like one with oil changes every other weekend. 3k mile oil service changes, plated, LC4 motor, and tons of punch for the street, commute, or fire roads. The 2004-2005 models SHOULD have been recalled from the factory regarding leaky (crappy) paper base gaskets. But they didn't, and that's when most of the SMC's ended up for sale. This bike has been taken down, and the base gasket was replaced. Mike Castro, local tuner, buttoned the motor back up, but not before a light port/polish job on the head, which made the bike really come alive. The bike was reassembled and it was almost like a lightened flywheel, type feeling. The bike has roughly 11k on it(will continue to go up as i ride it)ONLY Motorex oil changes every 1500-2000 miles. K&N and factory ktm oil filters have been used. Possibly the reason why when it was apart, looked new inside? At any rate, here are the following modifications.
KTM factory airbox
JD Jet Kit
Both exhaust pipes decorked
Head was cleaned up a bit. Nothing radical. Mostly polishing.
KTM Hardparts headlight
KTM Hardparts black mask
KTM Hardparts cyra handguards with handguard protectors
KTM Hardparts black front fender
KTM Hardparts black rear fender
KTM Hardparts front and rear axle sliders
KTM690 Maguara clutch lever/mastercyl
Brembo brakes/Caliper
New battery
New starter
2nd - 3rd gears and dogs just replaced, along with shift shaft
Carb completely cleaned in July
Valves adjusted 500 miles ago
Bridgestone Battleax BT002's Moose thick tubes Clean
title WA state title, free and clear-Newer tabs
has extra plastics, enduro tires, and spare counter shaft sprockets
will consider part trade for 250-340 dirtbike + cash
4500.00
cash, paypal, visa accepted
shipping at buyers expense. will crate, and help get to the shipper if need be
1 - 2 of 2 Posts
