Up for grabs is an original PCS Daytona Turbo Monster, built in Daytona by PCS. 15,000 Miles on the clock. Extras include but are not limited to:
Turbo Kit: IHI Turbo (rebuilt by PCS and has 20 Miles on it), Makuni Flat Slide Carbs, Custom Exhaust, Custom Intake hood, Boost Gauge, Fuel Pump and Regulator (105BHP)
Marchesini Wheels (Aluminum)
Dyna Coils
888 Ohlins Rear Shock
Brembo Brake Master
WoodCraft Clipons
Storz Damper
Cast Iron Floating Rotors
Rear Suspension Loop Risers
DID 520 X-ring Chain
Lightened Flywheel
Custom RearSets
Intergrated LED Tail/Blinker
Corbin Seat
Carbon Front,Rear,Hugger Fender
Carbon Seat Cowl
Carbon Belt covers
This bike is truly amazing. The Flat spot between jets is to much fun, especially when the Turbo Boosts, holy hang on. Bike runs very well and is a lot of fun. Has all the right bits from this period. Tank has a couple little dings in it and the Charging system used to cook the Battery (rectifier was replaced to stop this) but the acid dripped and took some of the paint off the frame and left side engine cover. Oil has always bee Golden Spectro Synth. $6750 OBO. Easy on the low ball offers, I will just part it out if I have no interest here. Open to Trades of 1997-2002 4 Valve machines (Superbikes) Thanks for the time.
Link to info on Turbo Kit:
DucCutters: PCS Turbo Kit (Mike Lee)
This is one of the four built by PCS.
High Rez shots can be seen by these links:
http://swingpad.com/db/Turbo/Dash.jpg
http://swingpad.com/db/Turbo/Front.jpg
http://swingpad.com/db/Turbo/Left.jpg
http://swingpad.com/db/Turbo/LeftFront.jpg
http://swingpad.com/db/Turbo/LeftRear.jpg
http://swingpad.com/db/Turbo/Right.jpg
http://swingpad.com/db/Turbo/RightFront.jpg
http://swingpad.com/db/Turbo/RightRear.jpg
http://swingpad.com/db/Turbo/RightTop.jpg
http://swingpad.com/db/Turbo/Tail.jpg
http://swingpad.com/db/Turbo/Top.jpg
http://swingpad.com/db/Turbo/Turbo.jpg
Dyna Coils
Brembo Brake Master
WoodCraft Clipons
Storz Damper
Lightened Flywheel
Custom RearSets
Corbin Seat
Carbon Seat Cowl
Carbon Belt covers
