Re: found this for you duc guys (superbike2001)
Update.. I spoke to the owner who did state he had another buyer that wanted to pay him the full asking price. Which I said fine and thanked him for calling me back. He said if it falls through then its mine, but I am leaning more towards this... 20k miles with full service history for $7k.... Going to look at it Friday if I can get the day off. What do ya all think? Good bad or otherwise.
Details:
Original owner had all service by Mike Duzick, MikMar Motors, Paxinos
PA.(northeast of Philadelphia).12k service performed at 11.5 k just before
my purchase
I performed the 18k service(at 17.3k mi.) I followed the the protocol per
the manual and all areas were addressed as follows:
-valves checked--3 shims needed to be changed(have worksheet with all
opener/closer clearances shims changed) All rockers in good cond. no
flaking(have pics i believe) cams pulled, lobes in good cond.
-new ducati kevlar timing belts
-new plugs(DR9EA)
-new fuel filter/newO rings base of pump and connectors
-oil/filter changed Mobil1 full synthetic( oil changed between every 1.5-2k
mi)
-Coolant changed
-flywheel nut retorqued
-cylinder heads retorqued
-engine mounting bolts retorqued
-airfilter cleaned
-replaced clutch drum. New barnett kevlar clutch installed
-front rotors replaced
I may include some of the tools to do the valves with the bike.
This past Jan./Feb. I checked the timing belts, changed oil/filter cleaned
filter screen as always, installed new oil cooler lines, cleaned air filter,
installes an anodized rear ride height adjuster/push rod.
Details:
2nd owner.....had the bike for about 3 years........have put about
9k mi. on it since purchase. Clear Title in hand.
-Forza CF slip-ons with chip(just repacked late last year)
-chain and sprockets about 4k ago
-CF Hugger, CF chin piece, CF front fender and CF clutch cover(neither
installed at this time)
-Kevlar brake/clutch lines
-Evo clutch slave
-billet crankcase breather
-Motobritalia bar risers with cycle cat brackets/hoses
-stainless steel hardware kit
-fan thermostat overide
-rear wheel nut socket(46mm)
-Madduc rear ride height adjuster push rod
-Mono and Biposto tails
-pass. pegs
-stock chin piece
-both tails included
-rear stand and dust cover
-Haynes service manual and LT Snyder manual. I've carefull documented all
the service I've performed. Saved receipts/packaging materials etc.
The bike is essentially in stock form(engine etc) save for the above
add-ons. Never been crashed. Previous owners wife tipped it over in the
garage(actually laid it over) trying to push it out of her
way.......otherwise no damage history.
