This link makes the rising rate more linear. You will have a better feel of the bike when exiting a curve which means you will be able to be quicker and harder on the gas.
Forsaken Motorsports Ducati Linear Suspension Link: 848 / 1098 / 1198
$470.00 * FREE Shipping
Developed and tested on a 1098R, this Ducati linear suspension link has a new and optimized geometry compared to the other links out there. The result is that there is no need to modify the shock length for the suspension to work properly.
You will need to increase the spring rate and get a shorter ride height rod to compensate for the linear travel.
Spring Rate needs to be increased ( +3).
Ride height rod needs to be swapped for a shorter one (like the one from Sato).
The links are fitted with Ducati bearings and seals.
CNC machined in billet 7075 aluminum.
Clear anodized.
Will fit 848/1098/1198.
Bellow is a list of spring rates to use on stock links. Weight includes the gears of the rider. When upgrading to our link, you should increase the spring rate by 15.0 Nmm.
140-160 Lbs – 80.0 Nmm
160-180 Lbs – 85.0 Nmm
180-200 Lbs – 90.0 Nmm
200-220 Lbs – 95.0 Nmm
220-240 Lbs – 100 Nmm
240-260 Lbs – 105 Nmm
260-280 Lbs – 110 Nmm
* FREE continental USA shipping on orders over $100.
* Outside continental USA, use shipping passwords:
GLOBAL250 gets 25% off shipping on orders over $250
GLOBAL500 gets 50% off shipping on orders over $500
GLOBAL750 gets 75% off shipping on orders over $750
* Register on the Motowheels website for Free forum passwords to access discounts on most non sale items or upgrade to VIP passwords for the deepest discounts on ALL items. Look for memberships and choose the membership type that fits you the best
