1 - 7 of 7 Posts
What's the best way to shape round corners on fiberblass? It's to hard to work with razor and the small saw tends to go straight. Does a wire saw would work?
Re: Fiberglass guestion (Giannis)
I use a machinest bur in my die-grinder.
The next time just lay out the patern and cut the corners first with a hole saw, then finish up with a jig saw
You might have better luck with a unibit to shape the corners.
A small die grinder with a very small cut off wheel is handy.
I usually use a hole saw, then cut it out with the grinder.
1 - 7 of 7 Posts
