My bike from Arkansas arrived a few days ago (I am in Colorado).
The guy rolled it off the truck, I hit the choke and key and she fired right up (has not run in approx 30 days when it was with shipper), so I thought yay!
The FI light however stayed on solid. This was not the case the day it went on the truck (seller sent me a video as the truck was there).
I am reading that it appears I may have a code 10 (baro sensor or connections), are these known for just coming loose? or is there a chance the shipper could have pulled it locking the bike in?
The bike runs fine and has plenty of power, doesnt cut out or die (maybe once if cold), and starts every time. It's just the FI light comes on as it primes, then goes off. If I dont start the bike, it will flash a single long flash over and over. If I start the bike it will come on solid. I have put ~50 miles on it without a hiccup, but I would really love to know what happened between Arkansas and Colorado.
Am I on the right track?
02 SP2
Full Akra titanium (obvious pair remove)
snorkel mod (not removed)
Power Commander 3usb
EDIT: I rode this ~11 miles to and 11 miles from work today, it starts fine, it idles fine, and has no bog or hesitation, nor does it just die like others. It runs very well, it's just the light staying on that bugs the hell out of me.
Do I need to re-tune a Power Commander to accomidate for elevation, or should it adapt and I have another demon?
I saw the lower cross member for the upper cowl broken right in the area of the baro wiring. I am going to pull the plastics today and check some connections and wiring. I saw in teh manual that the bike will still run fine with it flashing (and it does), just annoying. I pulled the power commander tune and it is running the base Akra 2:2 full with flapper mod (PC map ending in 10), with the exception of 0% throttle in the mid RPM range, I am richer by 4 or so, but again only in teh 0% range. Thinking that was done to control decelleration backfire?
Update: disconnected battery, removed tail and upper front cowl and disconnected and reconnected every connection I could find. Nothing looked corroded. Verified Baro sensor worirng was in tact and nothing appeared to be rubbing anywhere. Cleared codes when I put it back together and it fired up with the same baro code (constant 10 flash until started), then FI light is on solid, died twice on me, but fired back up right away.
Should I try a zero map on there and take away the richness from the PCIII? I am still up in the air as to what happened during transport to cause this other than the baro physically taking a crap while sitting still....
02 SP2
