Re: (DesmoDog)
You will also see that square edges and hard folds are not common inside as this does create a lot more boundary layer drag from adjacent surfaces hence creating flow disturbance, a clean flow line makes the gases flow, tighter bends formed properly don't have to bigger impact but the sizing does, dependant on where you want you power range you can up or downsize the pipe (within reason) to assist shifting your power curve along with the usual other items of remapping etc.
Another factor is where balance pipes are placed, this can greatly effect where you power delivery comes in, when I gutted the MH pipe I found out all sorts of information for performance enhancing exhausts etc, when it really comes down to the hard ass nitty gritty, an open style muffler and pipe with good clean flow lines and adequate size is all you need, you can tune the fuel system to it with great results and for the average street rider you will find that great.
99% of pipe/muffler manufacturers claim all sorts of figures, truth is they are all very close and unless you do other adjustments to air intake and fueling the gains are minimal.
Sound is the biggest improvement for street use, unless you are up on cutting edge racing you can spend a fortune for not a lot.
