Ducati Oil Change Kit: MOTUL 300V 10W40 Factory Synthetic Oil [4 Liter] & Oil Filter
Price: $77.95 *
Ducati Oil Change Kit: MOTUL 300V 15W50 Factory Synthetic Oil [4 Liter] & Oil Filter
Price: $77.95 *
Full Synthetic Ester Based Oil available in 10W-40 or 15W-50.
300V Factory Line lubricant takes advantage of the ESTER Core® Technology to ensure you maximum power output of the engine without compromising the reliability and the wear. By selecting esters over other high performance synthetic base stocks and combining them with an innovative additive package, MOTUL has created a perfect blend dedicated to the engine, the gearbox and the clutch.
With a temperature range of 365° F. 300V is completely POLAR in molecular structure, causing it to bond to metal and protect against metal-to-metal start-ups. Provides up to five times more film strength than petroleum motor oils.
The Ducati OEM filter or K&N Filter included is for all Ducati motorcycles 1991-2015 with the exception of the Ducati 1199-1299 & Ducati 899 Panigale.
MOTUL 300V 15W50 Factory Synthetic Oil Change Kit: Ducati 1199/1299/899 Panigale
Pricing: $89.95*
Complete oil change kit includes, oil, drain plug gasket, Panigale filter, and O-rings for filter cover
Includes your choice of K&N Oil filter or Factory Ducati oil filter for the Panigale series, oil, drain plug crush washer, and two o-rings for the filter cover.
* FREE continental USA shipping on orders over $100.
* Outside continental USA, use shipping codes:
GLOBAL250 gets 25% off shipping on orders over $250
GLOBAL500 gets 50% off shipping on orders over $500
GLOBAL750 gets 75% off shipping on orders over $750
* Register on the Motowheels website for Free forum passwords to access discounts on most non sale items or upgrade to lifetime VIP passwords for the deepest
discounts on ALL items.
Look for memberships and choose the membership type that fits you the best
CORSE DYNAMICS Magnetic Oil Drain Plug V2: 12mm [Deep Sump & EVO]
Pricing: $22.95
Corse Dynamics oil drain plugs are a great way to upgrade your Ducati with a part that is both beautiful and functional!
• Our "double hex" design allows you to remove or install these plugs with either the factory tool OR an ordinary wrench or socket.
• Our plugs incorporate a Viton O-ring to ensure proper sealing against the engine. This provides a good seal every time
• Our plug comes pre-drilled for safety wire on all six faces. Our plugs include a rare earth magnet to collect any metal bits that might be inside your engine, our magnet is rated at six times the strength of other competing companies.
• Made in the USA.
New feature of the Version 2 (V2) drain plug, we are the only company to broach the allen key in the drain plug to ensure ultimate strength, this manufacturing process is often over looked because of high tooling cost versus milling a hex with 6 drilled holes on the end. Those 6 holes leave weak points in the hex that are prone to failure with thin wall aluminum.
Fits: 996R, 998, 998R, 749R, 05+ 749-749S, D16, S4RS, 848-1198, SF, MTS1200, M696-796, HM796, Diavel...
CORSE DYNAMICS Magnetic Oil Drain Plug V2: 22mm
Pricing: $18.95
New feature of the new Version (V2) drain plug, we are the only company to broach the allen key in the drain plug to ensure ultimate strength, this manufacturing process is often over looked because of high tooling cost versus milling a hex with 6 drilled holes on the end. Those 6 holes leave weak points in the hex that are prone to failure with thin wall aluminum.
Fits 851-888 SS750-10100, M600-M1000, S4-S2R-S4R, 748-996, ST2-ST4S, Mh900e, MTS620-1000, HM1100, Sport Classics....
* Register on the Motowheels website for Free forum passwords to access discounts on most non sale items or lifetime VIP passwords for greater discounts on more products.
