·Guest
http://tinyurl.com/7y4bu "klanking" sound. ST4.
Nichols Basket and Barnett clutch pack. Clutch lever OUT, lever IN, and then lever OUT again.
http://tinyurl.com/3vq4l "Ta Ting" sound (air-cooled Monster)
My ST4 dry clutch has never made the "Ta Ting" sound. And even with the Nichols Aluminum clutch basket and Barnett aluminum fiber plates it still makes the "klanking" sound. The tabs fit the basket with less than 1mm clearance.
I think the klanking sound is the straight cut primary gear set, and the Ta Ting sound is the tabs in the basket. I may be wrong.
Straight cut primary gears transfer power with less loss, however they're noisy as heck. Honda once used straight cut gears but they made one of the gears a two-part gear that was spring-loaded so that there was a constant load on the gearset. It was nice and quiet. Not sure how they do it now.
It doesn't take much of a load to quiet down the gear set. Just pulling "in" the clutch lever does it on my ST4. However I still have never heard that Ta Ting sound from my stock basket or the Nichols basket.
The flywheel nut is tight.
Modified by DanST4 at 10:47 PM 2/5/2005
