Re: (jager)
Tbone your in az right? If so get a drz400k if you like kicking or a drz400e if you want electric start. All you have to do is go down to the dmv with the title(or a copy if you finance) and they will give you a plate. You don't even need to bring the bike down. My k is about 40 lbs lighter then the s, has higher compression, the keihn fcr 39 carb that everyone wants, and it only cost 40 bucks to register for the year, ins. is 20 bucks a month. I was able to talk the dealership into throwing in a set of excel 17" wheels and I have a 42 tooth sprocket mounted on the motard rear (stock is 47) and im waiting on my 320 mm rotor for the front. It takes 20min for me to swap over as it is and I still have to swap the front rotor. Should take 10-15 once I get the 320. The k or the e model (k with electric start) is the best bang for the buck. they are cheaper then the s or sm, make more power, are lighter and my bike is a street, track, dirt bike.
