Re: DP CF side panels (2vtwin)
For minor alterations/trims I always use a hand file followed by wet and dry (wet). If you must use your Dremel, the sanding drum would be the tool to use, just be careful, it's very easy to overdo it and remove too much. Whatever, finish by hand using wet and dry (wet), 320 grit to start with.
