·Guest
I'm a new rider to the track and I'm looking for some advice on downshifting into turns. I've done a few events at VIR and I'm starting to get very comfortable with running around the track, however I seem to always find myself screwing up getting ready for a turn as I brake and downshift, mostly coming off of a long straight. What I have been doing to date as I prep for a turn is to start easing back on the throttle when I come up on the brake markers, usually the first one since I'm still a sissy
(but I'm not chopping it so I get hit in the a$$). As I roll off the throttle slightly, say I was in 4th coming up on the turn, I will begin applying brake pressure to get to a speed I feel I can safely make the turn at, then I will do two quick downshifts to second, release the clutch as smoothly as possible, roll into my turn and then start applying the throttle again. The problem seems to be that as I release the clutch, the bike starts wobbling hard sometimes, too much RPM for that gear, or stutters as I don't have enough RPM for that gear. Either way, it is preventing me from being smooth into the turns since I don't have the chassis settled down as I start turning. I've tried engine braking, but this gives me incosistent results on my entry speed and usually a hard wobble as well.
I'd like to get this more smooth and under control so I don't have to fight the bike going into turns after long straights. As a crutch, I've started going into the turn at a higher gear and fortunately the bike has enough torque to pull me though, but I'm not getting good drive on exit.
Is there a better technique? Or do I just need more track time to smooth it out?
