1 - 3 of 3 Posts
has anyone been able to mount two bulbs both with low and high beams, so that when you switch on the high beams it's two bulbs blasting down the road?
Are the lenses the same on both sides? Or are they different?
well i have never ttried this but it has been asked here several times.
the two headlights are different. from what i understand the blulbs are the same. its the refletive lense behind the bulb thats different and makes the high beam brighter. i think you would be better off just doing the euro mod if you are wanting something different.
i purchased the sylvania silverstar lights, and i adjusted the low beam up a little and the high beam down alot. this way i run both lights on all the time and this also eliminates the idiots from telling me i have a light out.
1 - 3 of 3 Posts
