Other than cost, is there a DOWNSIDE to using these plugs? Mostly street riding.
DENSO SPARK PLUGS - Basic Knowledge
So you're paying $30+ PER PLUG??? I'm not talking about the standard iridium plugs. I too have done the CBR coil mod, but use turned-down NGK plugs. I'm thinking about going with Denso next, but considering the RACING plug, which is totally different from the standard iridium...I use them. If you do the CRB coil mod, you pretty much have to use them. Quality plugs IMO.
Where are you getting your turned-down NGKs?use turned-down NGK plugshttp://www.globaldenso.com/en/products/aftermarket/plug/racing/features.html
If you do, let us know if it made any difference.I'm thinking about going with Denso next, but considering the RACING plug, which is totally different from the standard iridium...
see this link: DENSO SPARK PLUGS - Basic Knowledge
Denso only makes the racing plugs for the SP1. I have an SP2, so haven't had a chance to try them. Would be cool if they had a set for the SP2 though.So you're paying $30+ PER PLUG??? I'm not talking about the standard iridium plugs. I too have done the CBR coil mod, but use turned-down NGK plugs. I'm thinking about going with Denso next, but considering the RACING plug, which is totally different from the standard iridium...
I had a machine shop turn them down. After labor, it didn't make economical sense to stick with NGK iridiums, doing 2 at-a-time, so I'm gonna use Denso from now on.Where are you getting your turned-down NGKs?
Actually, that's a misprint. I told my buddy at Denso to fix that. The RACING iridium plugs would be the same for both SP1 and SP2, just like the standard iridium plugs would be the same for both the SP1 and SP2. The dead giveaway to the misprint is the heat range for what they recommend for the SP2...WAY TOO HOT!!! Should be a 27 heat range; not a 20, which is 3 levels hotter... So in NGK speak, that's like moving from a 9 (recommended) to a 6!!! Obviously wrong...Denso only makes the racing plugs for the SP1. I have an SP2, so haven't had a chance to try them. Would be cool if they had a set for the SP2 though.
DENSO SPARK PLUGS
