How can I know that everything is perfect? I'm going to measure the caliper mounts as mentioned by CBR. How will I know if I'm squeezing/pushing the forks? Everything looks ok. I'll post pics tomorrow.
Did you install the bearings OR did the rims come with them?
IF You didn't know, there's a "Spacer" that goes in between the bearings through the hub... which is what I was referring to in my first reply.
IF there is NO spacer there, when You tighten the axel it WILL pinch the crap out of the bearings and IF You are not careful, it WILL damage the bearings too!
Were the rims you bought (NEW or Used) for the RC51,
If NEW it should have the correct spacers with them OR You're supposed to use your OEM spacers... Any paper work with them?
IF Used, do You really know IF they were for your set-up or could the Seller be wrong, You know what I mean.
Easy way to find out about "OAL" is to take your OEM rim and put both spacers in place on the outsides of the bearings, (just like your ready to install them into the forks) now all's you need to do is "Measure"
... Now you know the OAL of your OEM set-up, make sure your new rims are set-up to the same OAL..
I Hope this Helps
Peace Jeff
PS. NO more replies from any US until you post PICTURES!
