1 - 4 of 4 Posts
while slippin on my yoyo slave and cleanin the front sprocket socket i noticed that the gear had several mm of play on the shaft....after 20k miles it looks like the toothed plate that locks the sprocket onto the shaft is really worn....is this a normal replacement item....thanks....
Discussion Starter #2
Re: countershaft sprocket end play (slightly ducatic)
Yes, that is a normal replacement item.
Discussion Starter #3
In and out play is normal rotating play is bad. If the teeth on the lock plate are rounded, get a new one!
Discussion Starter #4
ouch....the counter sprocket locking plate is definately worn out and the replacement is in dealer stock for ONLY $10.75 plus tax....would recommend periodic inspection or replacement of this part....ya don't need this gear jumpin round....
1 - 4 of 4 Posts
