CORSE DYNAMICS Titanium Cush Drive Pins (Set of 6): Ducati Single Sided Swingarm
CORSE DYNAMICS Titanium Cush Drive Pins (Set of 5): Ducati Single Sided Swingarm
No detail was missed with the design of this cush drive system. Corse Dynamics looked at all cush drives on the market (past and present) and came up with something better. They came up with a product that is lighter, more durable, longer lasting, better finished, better fitting and safer than OEM or anything else on the market.
The titanium cush drive pins feature full titanium construction CNC machined to a flawless finish. Common with titanium blind broaching (cutting the allen key) chips form in the bottom of the bolt causing imperfections, we specifically designed a special tool to back bore the broach in order to prevent chip imperfections leaving a beautiful functional finish. The pin also features a safety wire provision and locating shoulder for the hub cover. Pin size is M10 x 1.25
This proprietary urethane compound is used in several motorcycle applications and has been extensively tested and now offered as a long lasting replacement for many aftermarket wheel applications. We have seen the performance of these cush drives last 5 times the life of OEM.
The outer cush drive aluminum sleeve features a retaining lip to prevent the cush drive assembly from backing out into the swingarm should the urethane come apart. The sleeve has also been hard anodized for a long lasting performance and finish.
The system for the Ducati 748-998/ 848/ Hypermotard/ Monster S2R-S4RS/ MTS 1000-1100 includes 5 cush drive pins, 5 cush drive urethane, & 5 cush drive outer sleeves. The system for the Ducati 1098-1198/ Streetfighter/ Diavel/ MTS1200 includes 6cush drive pins, 6 cush drive urethane, & 6 cush drive outer sleeves
The cush drives are 33% lighter than OEM.
