1 - 16 of 16 Posts
Does anyone have a good way to get that nasty hard crap off? The previous owner didn't I know that.
tried a seach already, sorry I didn't find any suggestions.
thanks.
RC51-less Member
heavyzee said:
Brake cleaner, industrial degreaser, or WD40, all work well
If you use brake cleaner, make sure it's Chlorinated brake cleaner.
Chlorinated brake clean is Trychloethylene.
Most Non-Chlorinated brake cleaner is Acetone. Acetone will harm paint, rubber seals, plastics and anything else that it can eat.
WD40 works well when mixed with elbow grease.
Kerosene. Naturally lifts, cleans, and lubricates rubber o-rings when used on chains. If you have any kerosene sitting around the garage not serving a good purpose, don't hesitate to dampen a rag with it and attack that rear shock. Just be sure to follow up with a clean, dry cloth to remove any left over residue. If you don't use kero this time, then just think about it the next time the chain needs a serious cleaning because I have come to find that kerosene is good for two things: making jet fuel and cleaning/lubricating motorcycle chains:D
Sign of Eth
I use 100% silicone spray on shock, linkage, to clean my chain, cleans, protects, and lightly lubes in one step, if you can move it lube it.:D
I've used Simple Green Max, you can get it at some autoparts stores like autozone. Its simple green but basically a degreaser. Works well and doesn't eat anything it shouldn't.
Discussion Starter #13
Great, simple green it will be, thanks for all the help. Let the cleaning begin.
Oh, how does it work at ZERO degrees? God I hate Minnesota.
Picks to follow
It ain't zero and and yur' HONDA deserves a good home, Bring it in the house ( eventually SHE will go away ) :twocents
Oh ya, wanna ride Tonka ice :rockon
Discussion Starter #15
Sorry, it was 1 degree when I woke up that morning. Not zero! :)
I thought about the basement, but I'm going to finish the basement starting in about a week, so too much sheetrock dust and crap for me to think it would be safe.
Kerosene is good for cleaning a chain. But it's hell on the tire. Have many marks in front of my house trying to burn the kerosene off the tire. Tire+ Kerosene = slick as ice.
Not sure what it has to do with cleaning the shock, but I thought I'd add my :twocents.
1 - 16 of 16 Posts
