·Guest
I've took the wheel off (replacing a slightly messed up rotor).
While i have it off, i decide to clean the calipers and deglaze the pads.
I took the pads out of the calipers, and had a go at the surface with a lil 3M light rust/paint remover disc.
Now, i am about to spray the calipers with brake cleaner. My question is:
Is it ok if some of the cleaning liquid oversprays into the piston openings, or should I avoid that?
Also, is 3m light rust/paint remove disc ok to deglaze the pads? What about the rotors?
Thanks.
Thanks.
