Chains other than DiD??
1111 Views 7 Replies 0 Participants Last post by  Guest
Anyone have any opinions on a chain other than DiD? I've done the searches and that one seems to be the unanimous choice but I was actually thinking about getting a red chain and looked at the EK's. Any opinions on that one or any others?? I was also looking through my SS performance catalog and DP sells one I guess under their name in red, but it's an RK chain. You can see it written right on the links. Thanks guys.
Side note...how long of a chain do I need when going up 2 or 3 teeth in the rear??
Modified by galaxy at 11:23 AM 2/15/2005
1 - 8 of 8 Posts
Re: Chains other than DiD?? (galaxy)
Just replaced the chain on my 916 with the second 525 RK-XSO series. Nice chain, I especially like the "rivet link" they use. It's center drilled, so it flares out nicely when using a center punch to secure the plate, instead of having the beat the snot out of the rivet to flare the edge over.
See less See more
2
Re: Chains other than DiD?? (TK)
The EK is a nice chain. I have two of them and raced with a 3rd. I would recommend them. I've also have had RK/DID/Regina and thier all very similar depending on what your looking for. O-ring, X-ring, etc.
Mileage may vary. Lots of people swear by a certian brand, and lots of people say that it really doesnt matter.
Personally, I had a RK chain snap at 10K miles. My DID has 12k, and the same maintence routines used, and still works great.
But I know lots of people who have RK's that work great. Really up to you!
Re: (rebelpacket)
One of the best chains made is the EK 520MVX. Not cheap though.
Do pretty much all chains require special tools to install or are some easier than others?? What's the best way to go? I don't know alot about chains or master links and stuff.
Re: (galaxy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by galaxy »</TD></TR><TR><TD CLASS="quote">Do pretty much all chains require special tools to install or are some easier than others?? What's the best way to go? I don't know alot about chains or master links and stuff.</TD></TR></TABLE>
That was a concern of mine when I installed a new chain. I didn't want to spend $80 to a $100 on a chain tool that I would only use a few times, and I didn't want to put a clip type link on the thing and go limping in to a bike shop asking for someone to rivet the "good" link on...
So, I found this http://www.jackssmallengines.c...s.cfm (rivet tool at the bottom) and it works very well. It is pretty much a Chinese knock-off of the expensive Motion Pro tool. For as much as I'll use it, it was money well spent and my rivet link is securely fastened. I really think you need a proper chain tool to install the rivet link. I'm sure it can be done other ways, but the tool does a nice job.
See less See more
Well, I've looked and looked at photo's and everything else and it's looking like it's gonna be an EK520MVX. Mostly because I have decided I don't want a gold chain, and that pretty much rules out DiD. Oh well. Thanks for the tip guys. Now, what do you think about a red chain??
1 - 8 of 8 Posts
