1 - 6 of 6 Posts
where do you guys generally mount the catch cans on motards? i can't find a spot that i'm happy with that is lower than the carb.
Re: catch can location (cb186)
On my Kawasaki, I ended up mounting it up underneath the motor to a side frame rail. I'd be happy to post a picture for you.
It took a loooong time to figure out where to get it to fit.
looking at mine(KX250) i think i may mount it on the top of the front of the swingarm, right behind the shock. that way i can run the stock lines into it, otherwisw i may run new lines and mount it between the frame rails in front of the motor behind the pipe.
Re: (cb186)
I located mine on the swing arm too...KTM's have a ton of room to mount stuff where other bikes usually have linkage...
1 - 6 of 6 Posts
