My 01' RC did not come with a seat lock assembly unfortunately. I'd like my PC to be "securely" locked in the tail. If I purchase a new one(if they can still be had) can a locksmith create a key for it? I've searched multiple forums and no answer.
Thanks, thats the answer I was looking for.If you buy the seat lock tumbler a lock smith should be able to make a key for it. The tumbler has a code on itself and the locksmith can use that for the new key.
I lost my key and couldn't get the numbers off the ignition lock or remove it so I used the seat lock to get a key and it worked for all the locks on the bike. Ignition, gas cap, and rear seat.
I am surely going to try this if such kind of problem occurs with me.Probably I choose Locksmith for such work because they have skills to make a duplicate key by knowing their number from sear or tumbler.So they are always the first preference..If you buy the seat lock tumbler a lock smith should be able to make a key for it. The tumbler has a code on itself and the locksmith can use that for the new key.
Well then you must contact the dealer instead of searching locksmiths around. They will get you the numbers.If you buy the seat lock tumbler a lock smith should be able to make a key for it. The tumbler has a code on itself and the locksmith can use that for the new key.
It's only possible if you show locksmith the key code else it's not possible for a locksmith to make it.If you buy the seat lock tumbler a lock smith should be able to make a key for it. The tumbler has a code on itself and the locksmith can use that for the new key.
