I was told that the bike should run off the alternator once started and since mine cuts off when you remove a battery lead I have a charging problem.
I've done the service manual checks and I believe my stator is working fine, almost positive my regulator rectifier is working fine and after studying the charging circuit I think the battery has to be in the loop for the bike to run. Can anybody confirm this?
If so, then I think I just have a bad battery and my charging system is fine.
