In stock and ready to ship.
BREMBO T-Drive 320MM Rotors
Fits Ducati 749/999/848/1098/1198/StreetFighter/M1100/S4RS/S4R 07+/MTS1200
THIS IS A BRAND NEW SET (2 ROTORS ) BREMBO T-DRIVE BRAKE ROTORS in 320MM FOR DUCATI (not available in 330MM, on 848/1098/1198/SF/MTS12, you must remove 5mm caliper spacer).
"T-DRIVE" ROTOR CONCENTRATES THE MOST RECENT BREMBO RACING TECHNOLOGIES AND KNOWHOW, UNTIL NOW EXCLUSIVE OF MOTOGP AND SBK. A SPECIAL "T" PROFILE OF EIGHT CONNECTIONS BETWEEN ROTOR AND DRUM IS THE INNOVATION THE MAKES "T-DRIVE" DISC SO DIFFERENT FROM TRADITIONAL VERSIONS WITH CYLINDRICAL BUSHINGS.
THIS PARTICULAR COUPLING ALLOWS TO TRANSFER BRAKING TORQUE MORE EFFICIENTLY AND GUARANTEES HIGHER RESISTANCE TO THERMO-MECHANICAL STRESS. T-DRIVE SYSTEM ASSURES BOTH RADIAL AND AXIAL MOVEMENTS (FULL FLOATING) FOR BETTER PERFORMANCES AND A WEIGHT REDUCTION WHICH GIVES A CONSISTENT IMPROVEMENT IN BIKE HANDLING. THE NEW ROTOR IS LIGHTER (REDUCED HEIGHT) AND MORE EFFICIENT THANKS TO THE NEW POSITION OF HOLES WITH DIFFERENTIATED DIAMETERS. ALSO THE DRUM CONCRETELY COOPERATES TO THE ACHIEVEMENT OF THE BEST RESULT: PRODUCED IN ALUMINUM ALLOY THROUGH CNC MACHINING, HAS BEEN PROJECTED TO GUARANTEE LIGHTNESS AND STIFFNESS.
MADE IN ITALY
5 bolt 15mm offset
Individual rotor weight is 3.25lbs
MADE IN ITALY
