·Guest
OK...this is turning out to be one of the most frustrating weekends I've had in a long time and I'm feeling like an idiot. My Evo slave cylinder started to seep this week, so I figured it was time to pull it apart and rebuild it. I emailed Evoluzione and they mailed out some replacement seals and a new piston right away with no questions asked. Very cool.
I go to install the replacement piston in the cylinder and it barely fits, and won't slide at all down the length of the cylinder. I'm bummed and figure I messed up somehow, so I reassemble with the old piston but new seals and bearing. The unit seems to work smoothly so I install it and start bleeding the clutch system...here is my procedure:
lid is resting on master cylinder but not sealed. I pump the lever for about a minute, then crack the master banjo bolt, repeating until I see no bubbles. I pump the lever some more and crack the slave banjo bolt, repeating until I see no bubbles. Action at the lever is fairly light, and the clutch isn't working. I then remove the slave cylinder and slowly compress the piston with my thumb, while watching the master cylinder for bubbles. Fluid seems bubble free, so i reinstall the cylinder, pump the lever and crack the master banjo...no bubbles. Clutch still won't engage when the bike is in gear. I removed the clutch cover and the plates move outward a couple milimeters, but that's it. There don't appear to be any leaks anywhere either. I've been doing this for HOURS.
Am I missing something? This was the same procedure I used when I installed the cylinder 4 years ago and everything worked perfectly. I don't know anything about the clutch, so would appreciate any input as to what I should look for in case there is another problem in addition to my slave cylinder. The Duc has been so much fun to own, but I'm getting pretty discouraged.
Jeff
Jeff
