1 - 3 of 3 Posts
I've done a search in here and ROGUE, and did all the possibly steps that I could.
Problem:
1. The bike won't start,
2. headlight ON, dash ON,
3. NO FI light, NO fuel pump 'whirring' , bank angle relay clicking.
What I checked:
1 .The battery is good.
2. All 3 relays (two for pump, one for bank angle) are good.
3. Fuses are good - 2 (30A) and few 10A in fuse box.
4. Try to 're-boot' the system by disconnecting the negative terminal and put it back on. ( I don't know why I did this, but I found it after doing a search here).
Right now, the bike still won't start. The PC3R also don't light up when the key is turned ON.( Yes, I did check the Kill Switch too).
Please help me..thank you.
Discussion Starter #3
After few hours checking the relays,battery, fuses... it turned out a connection from battery to PC3R was disconnected. Sorry for the time guys... sometimes, the simplest thing is the solution.
1 - 3 of 3 Posts
