·Hi I use to have my battery tender hooked up all the time?? but it seems when I have it hooked up for awhile you can hear the battery bubbling, and one time my bike would not start because the water/acid level was bone dry...
so I think my battery tender is messed up??? should the battery be bubbling...?? on a tender. I had my battery refilled with acid and is fine but It still bubbles..??? is this normal?? Is it just because my battery is old ( Is the brand FIMM the orginal battery?) and the tender just keeps overcharging it and evaporating the water/acid??? or does it sound like my tender is gone?? the charging and all the lights on the tender seem to be working just fine turns to green when the battery is fully charged??
Also would I have better luck with a sealed battery??? but would this still happen (water/acid evaporation)??
Thank you.....
Modified by DucatiR at 5:50 AM 4/2/2005
Thank you.....
