I picked up some CF slip on exhausts for my 1994 M900. The right side seems to go on just fine. The left not so much.
I have attached a picture to display the problem and clarify any mis-conceptions I may write.
This problem with the mounting holes lining up is caused when I push the exhaust pipe all the way into the header piep. Not hard mind you, but until the exhaust pipe stops. If I line up the mounting holes the ehasut pipe is only in a little bit (I have not measured how far it goes into the header pipe when the holes line up, but I can if that helps sole the problem)
My question is how to fix this problem?
Can I drill out the rivets and then re mount the braket with new rivets? If I do that how do I seal up the old rivet holes?
Any suggestions are appreciated.
I have moderate mechanical skills, but I have a firend who is an expert motorcycle mechanic. So anything I cannot do, I will have him help me with.
Thank you in advance!
