1 - 6 of 6 Posts
I changed my watter wetter from the new bike to some anti freeze for the winter. I filled her up and ran the bike without the cap on as suggested in the manual. After a while the bubbling became so bad it just spat damn antt freeze out and i shut her down:banghead I then filled her up again and this time i had the rad cap on. I let it go until i saw the fans come on and shut it down and checked the level.
Is there anything else i should do? why did it burble like that? just wnat to make sure it is good to go for the cold
TIA
Enormous Member
TIA
It spit at you like that due to the air pockets created when you drained it, very common.
What happens is the coolent comes up to a boil in spots around the motor that these voids exist. the thermostat begins to open and the high pressure is released causing these little eruptions.
You will probably need to burp the system a couple times and top it off before you are finnished
Enormous Member
mrgrn said:
thanx, so dare i run it again with the cap off? or just run it with the cap on and check the level after cooling?
PS, do you still want those front Brake caliper adapters Robert? i can ship for monday, on me no problem.
Nah Mark I Have the adaptors. I need a front wheel
Leave the cap on and follow the standard purge method. The one in the service manual works.
^I just got a service manual off of ebay for 40 bucks. I haven't seen the official Honda version but this one seems good.
1 - 6 of 6 Posts
