Re: (Jeff H.)
Jeff:
Fit is pretty good. They run a little small like the Dainese. I would say definitely try one on before you buy if you get the opportunity. Either that or go one size bigger than you normally wear. I am 6'3" 210 pounds and I got a 48/58. I normally wear 46/56. The sleeves are long enough which is nice. Shoulders are a little tight, but I think it will be fine. The overall length is great and plenty long. It has the hard armor in it which is removable. Some people complain about the forearm armor being too hard and bothering their elbows. It doesn't bother me, but then again I am no body builder and have a girlfriend so my forearms aren't huge.
I figured if it bothered me that I would just line the inside of the armor with a 1/4" foam, but it isn't an issue thus far. I have also heard people complain about the neck portion being very hard and stiff, but say once broken in that it is a non issue. I have to agree, it IS very stiff, but I am sure it will get better. It comes with a liner which is removable. The liner is more of a vest and doesn't line the sleeves.
We lucked out on the weather today and it was only 80 degrees. The venting felt fine (Liner removed). I will be able to tell more next week, as it is supposed to hit triple digits here. Will let you know if you want.
