On page 5-77 of the manual it states the Air INjection system. This consists of a canister with two small hoses. One goes to the front throttle body and the other to the selanoid valve mounted the clutch side radiator.
What is this and what does it do?
I am in the process of removing the PAIR system, which I'm good with. If I can remove this...why not.
I do not see what this does, except add air to the front throttle body. It is not hooked up in any way shape or form to the fast idle (as that is just a slide on the throttle rack.
Thanks.
Edit: This is what I am talking about Ronayers.com Fiche Desktop Motorcycle Honda 2003 RVT1000R VACUUM TANK 02-04
Thanks.
