1 - 11 of 11 Posts
Who has experience with adjustable triple clamps on RC 51's?
I would imagine starting @ -1 to quicken up the steering is a decent start for an SP2.
Who has played with offsets?
Re: Adjustable Offset (eye-p)
i,ve got adjustable clamps.After raising the rear i found the front more twitchy so i pulled the forks back a bit to increase trail, this gave me back the stability.Really it's a balancing act till you find what's good for your type of riding.
I have used them before. That should help on having to buy bushings.
What did you do for a damper mount?
Re: (eye-p)
I have the Ohlins with Harris brackets.I fabricated a new stem nut, as the Attack or Harris ones were no good with this combination of parts.Also had to do a slight mod on the Harris top triple bracket.Hope this helps.
Re: Adjustable Offset (zippy)
I have just raised the rear through tire change and my front end is twitchy as well... could I just drop the forks in the tripples a mm or 2?? the only negative I think this may have is the fact that I may need a step ladder to get on her, and i am already 6' any input may help (sorry about the hijacking)
Re: Adjustable Offset (Rocryder)
I don't have pics, i've never posted any but i'll maybe get some and see if i can.
1 - 11 of 11 Posts
