1 - 3 of 3 Posts
1MNpunisher said:
got a ? for you, I switched out my PC2 for a PC3 someone had spliced out from the PC2 into to a red connector under the left side of the engine near the coolant bottle. I unhooked the splice and plugged the two back together. Just wondering if this was the soft rev limiter splice or something completely different. Just wondering if you might know what that is, Thanks Joe
Ps I started the bike but havent ridden it yet, but it seemed to run/start fine.
I know when I did my soft rev limiter mod, it was all done under the seat! My 04 had a PCIII on it before I bought it, so I have not looked where it's all spliced in to! Hope this helped a bit!:banghead
The soft rev mod is done under the seat on the ecu box. There should not be any wires cut or spliced on the pclll. They come ready to plug and play from dynojet. PClllr does connect on the red plugged ignition wires behind the coolant tank. (so ignition timing can be changed) PClll USB does not connect to the ignition wires.
1 - 3 of 3 Posts
