On that note.. I am no longer posting anymore and removing myself from this website. I do not want to waste my knowledge or time with people not interested in performance. The people here only seen interested in making uneducated, negative comments.
What's wrong Haime ? Testy 'cause Rossi won't be around to bash for a while longer ?He read it on the Internet so it's true, duh?![]()
Don't be mad at me cuz you're little BFF left the site and won't be able to "stroke" you.What's wrong Haime ? Testy 'cause Rossi won't be around to bash for a while longer ?![]()
Check out this little nugget in the pics of the kainzinger bike:The stroke enlargement is a single order dimension increase, so if you were to add 2mm on the journal axis it would be 4mm increase of stroke, ~7% increase in displacement.
The problem here is if this crank fits in the crank case, you need clearance between piston skirt and crank. So you may need a longer rod by at least 2mm to have the same clearance as before, while pistons don't have that much to begin with. You already had the piston with stock rod going 2mm higher, and if your new rods are an other 2mm longer, the piston now travels 4mm higher.
Since this engine's cylinders do not separate from case (in those cylinders you just add a spacer on the bottom of them and raise them, which you can not also do to the valve train on the RC) your piston rings are running out of cylinder, so you need pistons with smaller distance from crown to rod pin/bearings. I say those were borderline already.
Without a longer stroke this engine is already oversquare, just adding bore size will not help it much.
But let's say you did all this and got 1150 out of it, will the transmission/cases hold the extra torque?
I say that piston shapes, valves, head, cams, have some room to worth playing with in an effort to get more rpms/hp.
It is not going to be a Honda when you mess with the engine so much so it might as well be a ducati. How about shoe horning an 1198 engine in the RC frame?
I subscribed to your thread, I can only imagine what that bike will feel like when done. Very nice.I stopped posting here because I just got tired of all the nonsense. From time to time I check my photobucket account and see may of the photo views are still coming from this site so I stop in now and then to read whats going on.
I did stroke my crank up 2mm to 65.6mm and had custom 103mm pistons made (comes out to 1093cc). We moved the wrist pin up 1mm rather than change the rod length. 1mm of extra throw should have no problem inside the crank case and the clearance to the piston skirt should be fine. The nice thing about +3mm on the pistons and +2mm on the crank the stoke/bore ratio stays the same (1.5725 vs 1.5723). The pistons are done, the crank is done, the case is off to be bored and sleeved now.
Im using Ti rods, custom C350 lightweight wrist pins and fully CNC under head milled pistons to keep the reciprocating mass low. Im also keeping the rev limiter very near stock. The extra stress on the crank will be at TDC exhaust stroke where the extra peak piston decel will try to pull the crank and rod apart. The lighter the reciprocating mass the easier it will be on the crank and rod but it still have to have enough strength to resist flex. It can be done but it gets very expensive.
I have already sunk so much in to it I have to finish it. Many times I wish I didn't start this project as Its taken far longer and cost far more then I care to admit. Once its done it there is no way to tell how long it will live, how much power it will make or how ridable it will be. We have a good idea on several of those aspects but only time, the dyno and the track will tell for sure.
Is it worth it? Hell no. I could have bought several other nice track bikes instead and been out riding. That said, I sure will be glad to hear it run again.
Mike is usually 100% correct in his sarcastic wisdom but I'm that one in a thousand fool that actually did it.
