·Guest
Hey guys,
Usually hang out on th rc board but I have Duc question so I figured I would go to the source. I have a chance to buy a race prepped 1999 750ss and was curious what it is worth. I will be racing at Loudon and currently have a 1994 raced prepped ex500.
Here's the goods:
99 Duc 750SS with 4,800 miles
Arrow highmount slip-ons with Ultimap flash
New Regina 520 chain and AFAM sprockets
Ducati Performance rearsets with GP shift
Forks have just been redone with Racetech Gold Valves and .90 springs Shock is a fully adj Sachs of a newer SS has an Ohlins spring for 200lbs, I
have the stock spring too.
Motor was just service and tuned by BCM, valve job, belts etc. BCM lightened flywheel BCM subframe modification and racing seat support ( they essentially lop off
8lbs worth of steel)
BCM frame modification (extra ride height)
Brand new Michelin S2 front and M2 rear (180/55)
Brand new Sharkskinz
Cycle Cat bar sliders (these replace the engine mount bolt with a stud and
attach to either end)
Spare set of complete wheels with Michelin full wets mounted on them (have 3
laps on them Afam sprocket too)
Spare set of new Michelin H2s
BCM stripped all street harnesses, smog gear etc. off of it. I have it all
in a box
Its fully drilled and wired
Thanks!
Here's the goods:
in a box
Thanks!
