1 - 6 of 6 Posts
MORE PHOTOS UPLOADED BELOW
Hi
I am having a change of plans on my current track bike project. So deciding to break this bike into parts. Old bike picture attached, more will be taken at weekend. Detailed pictures can be taken for bits of interest. Please qualify your interest via U2U or email and I will get in touch when I start breaking the bike.
Few interesting RS bits:
- Race forks (reserved)
- 998RS wide track yokes complete with fully adjustable off set in black (looking for offers over £1500 available)
- Brembo GP calipers 40mm mount, billet, 2 pieces 36/32. (SOLD)
- RS small axle (will fit a standard swingarm). Can sell stand alone or with RS floatting disc, bobbins (Reserved)
RS alloy nuts, quick change sprocket carrier, etc. - still available
- Small Brembo rear billet P24 caliper £450 (available)
- RS billet Caliper carrier - £150 (available)
- RS fitment wide track front wheel & big hub rear wheel. I have some pairs in 16.5". fully refurbished. £700 (available)
Note - the photos are not showing the bearings, etc. Those have been removed for refurbishing but will be sold with the wheel (inside spacers, bearing, outter spacer)
- 748 RS underseat breather. (SOLD)
- Pierobon alloy front subframe - £150 (available)
- 290mm RS front brake discs. Ok conditions but bobbins a little tatty on one side - £130 (available)
The rest of the bike is pretty much standard and also up for grab:
- 996 Engine.
I have cleaned up the top end completely. Changed few rockers, done the clearances, new head gaskets, cleaned the valves & resitted them, some new valve seals. Thorough clean up in the process, billet water unions, etc.
Just needs fresh belts and clean oil and ready to go. I can do that for you if needed.
Looking at about £700 without clutch
£1000 with slipper clutch.
Please see engine running at:
http://youtu.be/VMGdh1E-O0w
(currently on eBay)
- Ohlins rear shock - Standard shock with easy adjust preload adjuster. £370 (available)
- SIL MOTOR 45 mm race exhaust (slip ons or complete system) - £250 (available)
- Techtronic digital dash. Wiring needs looking after a bit. £250 (SOLD)
Many other things like:
- Clean swingarm powder coated black £200 (available - on eBay)
- Clean standard tank in Red No fuel pump - £130 (available)
- billet cap £50 (available)
- 748 alloy rear subframe (tatty) £80 (available)
- Carbon airbox (bit tatty - started as RS, modified for standard frame and tubes, some carbon cut at back, clips only on one side) £80 (available)
- Carbon airtubes (standard size, tatty, no bits for clips) £80 (available)
- Possibly BREMBO GP Radial Brake Master Cylinder and Clutch Master Cylinder (SOLD)
- standard 996 throttle bodies £120 (available)
- Just re-powder coated frame in Ducati red (it's a US import with papers and visible frame numbers, working out how to get V5) £250 (available)
Shipping done at cost, collection welcome from Surrey/Greater London
1 - 6 of 6 Posts
