1 - 3 of 3 Posts
Anyone know if the upside down fully adjustable 43mm HMAS forks on the RC51 or 1000rr will bolt on to the VFR triples? ANy issues with break mounting and/or wheel axle?
Considering a VFR but need a little more adjustability.
Thanks
I don't think they would be interchangeable without the triples. a VFR is a standard fork right? The part that goes into the triples on a 1000rr and a RC51 is 50mm. You might want to check the triple tree stem diameter, length etc and see if they match up, if they do you SHOULD be able to swap the entire front end out. Hope this helps
1 - 3 of 3 Posts
