·Guest
OK, here's my spec's...
Verticle Cylinder Openers...I=.004 E=.005 Closers...I=.003 E=.001
Horizontal Cylinder Openers...I=.005 E=.005 Closers...I=.002 E=.001
Right now I'm thinking I should adjust the horizontal intake opener (.005) and the verticle intake closer(.003)and everything else is good??? No? If you convert the factory specs to inches it gives all openers .002-.006 and all closers .000-.0078. According to these specs, I'm in there across the board. Just want to get your inputs on this or what you would do?
**If you change a closer shim on a valve will it throw off the opener clearance or should it remain unaffected?
**On openers and closers, if you need to tighten up or reduce the clearance, you need a 'thicker' shim correct? And this applies to openers and closers??
