1 - 20 of 40 Posts
I wouldn't be very surprised if the listed 198kg is dry weight b/c of the heavier crank , cases , gears , etc. necessitated by the big-bang config . There just might be another muffler on the other side for the same reason . Needless to say , they're going for tractability and grip instead of the HP crown . There's nothing better than new ideas . Can't wait to try it !
Too little info to draw any firm conclusions but given the hype being built up around this bike, it had better be good or it`ll be a real kick in the gonads for Kawi.....
V4 CyclePath...
Question is??? did Kawasaki offer their MotoGp Droner or just wrapped the old
status quo Screamer with new body work???
Señor Member
But the crank is identical to a even firing order inline four, according to what I have read. It just fires the pairs of pistons simultaneously instead of 360 degrees apart. If there's more weight to it, it's in the electric motor that smooths out the low rpm operation.
It's my understanding that even with a flat (180) crank , the extra stress of firing 2 cylinders together requires beefier parts . We'll see if the bike is indeed a big-bang as the rumours indicate .
nope, just sticking to the facts ;) Besides, the word baiting takes on a whole new meaning with Fester... anything that shows up on a computer screen inevitably results in some long-winded V4 distribe, dramatically broadenig the application of the word.....
He with the senior member
Yup, this was part of the problem Ducati had with their early Twin Pulse big bang 990 MGP motors when they wanted to move from the screamer 360 V4 format. They soon switched to a staggered pin big bang sequence, to allow a small spread of the crank torque and avoid breaking gears, clutch, etc while still having a nice, long rest period.
The motor can be built to withstand the double torque loads of course (assuming twin pulses simultaneously), but it'll clearly need to be stronger and heavier than a cross-plane or standard 180 sequence
LOL , so maybe they are going for the HP title with another screamer , as is Kawy's tradition . That single , small muffler alone indicates it can't be a true big-bang which I think would require more exhaust volume .
hmmmm, doesn't sound like a regular 180 I4 firing sequence to me. It also doesn't sound like a double twin-pulse, so I'm thinking it has a standard 180 I4 crank layout and fires 2 pistons at the same time, but the other 2 are sequenced normally, so 3 firing events per 720 degree cycle instead of 4.
I have always wondered how that set-up would work. From a traction standpoint I would think it would work well but the stress on the crank and drivetrain would be steep. BIke has a nice growl to it though...
Señor Member
Why would it be steep?
The two pistons firing together have less displacement than a single V-twin piston, and they are doing it through a shorter stroke, turning a crank with more rotational inertia than a v-twin crank.
What am I missing that makes this arrangement so hard on the crank and transmission?
1 - 20 of 40 Posts
