My 05 R1 Track Build. - Page 2 - Speedzilla Motorcycle Message Forums
post #21 of 24 (permalink) Old 06-13-2013, 02:16 PM Thread Starter
Originally this was going to be a slow Build process but I decided I wanted to ride it this year at Heartland park.
Forks with Ohlins 20mm kit are back, along with the Ohlins rear shock. and bike is back to being a roller and is now at my buddies to get bodywork fitted and painted.
Just bought a Used GPR V4 Damper to delete the factory damper and mount set up.
PC3 is installed and working on setting up the ignition switch delete. I hate needing keys for the track bike.
post #22 of 24 (permalink) Old 06-14-2013, 07:51 AM
Member (Large)
b.miller123's Avatar
Funny how purposely slow builds never wind up going slow... and ones you try to do quickly never get done fast.
The ignition delete should be simple enough, especially if it is like the R6. For my bike there are five wires coming from the switch. Hook the two small blue ones together, and then put a switch between the two bigger red ones and ignore the third brown one. At least that is what the forums say anyways.
Yamaha doesn't use resistors in the switch like other oem's. Heck even my '98 ninja 250 uses a resistor.
b.miller123 is offline
post #23 of 24 (permalink) Old 06-14-2013, 07:21 PM Thread Starter
Mine the big wires are Brown red and orange. The red and Orange are actually the same wire(farther down the wire).
I have the small wire crossed. need to mount a switch where the factory ignition was then wire it in and be good to go.
My GSXR was a little more difficult but once I found a diagram it was easy. I made that one all controlled off the right side Bar switch. Was great for track days.
post #24 of 24 (permalink) Old 06-17-2013, 04:42 AM
Member (Large)
Sounds exactly like the R6. The one wire you ignore is the one that joins the other down the line.
I have a couple toggle switches laying around from when I had to hot-wire my ninja years ago when my friend owned it. It looked like shit, four toggle switches on a project box from radio shack. He had to get the "missile launcher" switch with the fancy led light and big cover. Looked ridiculous.
I do have a dead man tether style switch that I'll probably use. It's been sitting in a box forever. Looks decent and mounts to the master or clutch perch. I might wire it in for the kill switch and put the ignition on the kill switch. My bike might see some street duty, so I'd rather not have just a toggle switch.
