05 Honda CRF450R fork oil level??? - Speedzilla Motorcycle Message Forums
post #1 of 2 (permalink) Old 06-08-2007, 05:17 PM Thread Starter
weasel's Avatar
Weight? Capacity in cartridge and outer leg? Don't have the book and can't find any info anywhere.
weasel is offline
post #2 of 2 (permalink) Old 06-11-2007, 07:13 AM
MotoGreg's Avatar
How is the weather in Ass Valley? Hopefully not breezy!
This is for '06 but I believe '05 is the same...
For the outer part...
standard spring 0.46 :standard oil cap. 12.7 us oz / 375cm
max oil 13.8 / 407cm
min oil 10.5 / 311cm
softer spring 0.44 :standard oil 12.9 / 380cm
max 13.9 / 412cm
min 10.7 / 316cm
harder spring 0.48 :standard 12.5 / 369cm
max 13.6 / 401cm
min 10.3 / 305cm
As far as the inner chamber you just fill it up and then it's real hard to get the cap pushed down because it forces the excess oil out. Once you have the cap screwed down onto the cartridge you have to blow all the excess oil out with compressed air (there are some holes to blow though.) If you don't that excess oil will end up in the main outer leg part and then you'll have too much oil.
In the old days I would use more oil (less air spring) so that the forks got stiffer near the end of the travel. If you try that with these twin chamber forks you just get super harsh action everywhere. These forks are undersprung even for average weight riders, you need stiffer springs and then use somewhere between the minimum and standard oil levels. For oil use the Honda oil for twin chamber forks, I think it's 5w. One bottle is enough to do both outer legs but if you do the inner chambers too then you'd better buy two bottles to be safe. Don't forget that heavier springs take up more volume inside the tubes so you have to use less oil to maintain the desired air spring effect.
'10 Ducati Streetfighter
'07 Ducati S4Rs -
'06 CRF450
And too many bicycles...
MotoGreg is offline
