SP2 swingarm width? - Speedzilla Motorcycle Message Forums
post #1 of 11 (permalink) Old 01-30-2012, 04:00 PM Thread Starter
Denmark
LKHanberg's Avatar
SP2 swingarm width?
Ive got a SP1 swingarm which measures 267mm on the inside, where the wheel mounts up.
I also have a SP2 swingarm, which has a dent, which only measures 264mm. Is it bent or is it supposed to be slimmer?
LKHanberg is offline
post #2 of 11 (permalink) Old 01-30-2012, 05:48 PM
sbk_drew's Avatar
So, you're talking inside to inside distance, right?
sbk_drew is offline
post #3 of 11 (permalink) Old 01-30-2012, 06:00 PM Thread Starter
Denmark
LKHanberg's Avatar
Thats correct
post #4 of 11 (permalink) Old 02-01-2012, 04:14 PM Thread Starter
Denmark
LKHanberg's Avatar
Anyone?
post #5 of 11 (permalink) Old 02-01-2012, 06:13 PM
sbk_drew's Avatar
I have a couple swingarms waiting at my machinists shop to measure. He has a 12" dial caliper so we were going to measure them tonight and I'll post up the results.
sbk_drew is offline
post #6 of 11 (permalink) Old 02-01-2012, 07:06 PM Thread Starter
Denmark
LKHanberg's Avatar
OK, many thanks
post #7 of 11 (permalink) Old 02-02-2012, 03:34 AM
sbk_drew's Avatar
Okay, they were both very consistant. Measuring across the axle span at the middle of the axle oval and at the trailing edge of the swingarm I got 10.480" at both locations on one swingarm and 10.520" at both locations on the other. Hope this helps.
sbk_drew is offline
post #8 of 11 (permalink) Old 02-02-2012, 02:29 PM Thread Starter
Denmark
LKHanberg's Avatar
Thanks, both are about 2mm wider than my SP2 swingarm then. But I can press it out with little force, but sure does make fitting the wheel a PITA. Maybe its a little tweaked.
post #9 of 11 (permalink) Old 02-02-2012, 02:57 PM
sbk_drew's Avatar
I'll have at least 2 or 3 swingarms with repaired stand spools for sale soon.
sbk_drew is offline
post #10 of 11 (permalink) Old 02-02-2012, 03:15 PM Thread Starter
Denmark
LKHanberg's Avatar
Are they they silver or black? And how much are you looking to get?
post #11 of 11 (permalink) Old 02-02-2012, 03:27 PM
sbk_drew's Avatar
They can be any color you want them to be, thats the beauty of it because after welding on new spool lugs they'll need a new finish anyways.
New lugs welded on, bead blasted, powder-coated, bearings and seals installed along with all the needed hardware.
If someone needed conversion sleeves those can be done too.
For the swingarm alone I was looking to get $250 USD plus shipping.
sbk_drew is offline
