Front Mount Radiators for Everybody! - Page 8 - Speedzilla Motorcycle Message Forums
post #141 of 239 (permalink) Old 01-11-2012, 07:02 AM
Originally Posted by TLRSKUNK View Post
I'm gonna need a set of these soon...
Rad kits are in the air - on their way to me.
They'll go quick.
TygaUSA.com - Tyga Performance Carbon Fiber, Exhaust Systems, Billet CNC & More! will be updated upon arrival.
WW
Thanks for your support!
Wildwhl is offline
post #142 of 239 (permalink) Old 01-13-2012, 05:58 PM Thread Starter
Rothmans's Avatar
New high polished version now as well which I think looks pretty good without being too much bling...photos soon!!
THERMAE
i am a assshole and really it all boils down to that.
Rothmans is offline
post #143 of 239 (permalink) Old 01-13-2012, 06:50 PM
Waldo's Avatar
Hey Glen, the site says you are out of stock in the SP1 Rads. When will you have more in?
Fast bike slow rider
Waldo is offline
post #144 of 239 (permalink) Old 01-13-2012, 09:44 PM Thread Starter
Rothmans's Avatar
Should be about a week, maybe 10 days, just waiting on a couple small bits to complete the kit!
THERMAE
Rothmans is offline
post #145 of 239 (permalink) Old 01-23-2012, 11:10 PM
Alright gang - we'll start shipping these Wednesday on a first ordered, first shipped basis! Only 4 kits left in stock and unspoken for (polished and painted for SP1 and SP2, respectively) for now - don't wait!
WW
Wildwhl is offline
post #146 of 239 (permalink) Old 01-24-2012, 04:54 PM
RC51 only 4stroke I liked
ZeroGara's Avatar
Comparison
How are these compared to stock in terms of volume?
Has anyone installed them and use them on the street?
Is there room for a fan?
"The most violent element in society is ignorance" Red Emma Goldman
ZeroGara is offline
post #147 of 239 (permalink) Old 01-25-2012, 08:32 AM
JBs_SP3's Avatar
I haven't compared the volume but I use the Thermae front mounts on the street and yes there's room for one or two SPAL 4" fans behind the lower radiator. It's hot here in Bangkok and I have a modified motor so I usually kill the engine at lights otherwise the fans are working hard to keep the temps under control. This is the same scenario I had previously with the stock motor and rads, the difference now is the bike cools down much faster once it's moving again.
Total frontal surface area is slightly less than OEM but the stock rads are partly shrouded by the engine hangers so in real terms there's more useable surface area in the front mounts, plus at 32 mm the cores are much thicker. In my experience the main advantage of the front mounts is the rads are de-coupled from the frame meaning less of the heat radiating from the engine hangers is being transferred back into the cooling system. The main disadvantage is access to the front cyl. and spark plug is now a PITA.
I never tried a 5" SPAL pusher with OEM rads myself but going by other people's experiences this together with some Thorston scoops looks to be the best all-round cooling system modification for stop and go traffic. A single 5" SPAL fan moves more air than either OEM or two 4" SPAL fans. The front mounts are trick though.
Hope this helps.
JBs_SP3 is offline
post #148 of 239 (permalink) Old 02-14-2012, 05:10 AM
BBB
Superhawk rad
PM sent
BBB is offline
post #149 of 239 (permalink) Old 04-09-2012, 07:34 PM
Bump for a great product, any word as to when new kits (SP1) will be available?
mtslesse is offline
post #150 of 239 (permalink) Old 04-09-2012, 07:42 PM
Contact thermae cooling directly. Thermae Cooling
Last I saw Tyga USA was closing it's doors.
Oh, and pick me up an SP2 set while you're at it.
and much more
along with
Aprilia SXV 550
KX450F
post #151 of 239 (permalink) Old 04-09-2012, 07:52 PM
Soon - very, very soon (weeks hopefully).
WW
Wildwhl is offline
post #152 of 239 (permalink) Old 04-09-2012, 08:02 PM
thanks for the link, email sent!!
Everyone who picked up a kit pretty happy? The quality looks top drawer! I think the worst part of this is going to be explaining to my wife that I just had to have them....forginess is so much easier than permission...
mtslesse is offline
post #153 of 239 (permalink) Old 04-10-2012, 02:24 AM
Dr. Carbon
20_RC51_00's Avatar
Hope this helps.
I would think that killing the engine at lights would cause you to heat up more since there is no air flow and now there is no fan either. and not coolant circulation. The coolant directly beside the cylinders is actually getting superheated relative to that in the rads ot tubes..... you might be doing harm not good by letting the coolant get hotter in these areas:twocents
20_RC51_00 is offline
post #154 of 239 (permalink) Old 04-10-2012, 02:44 PM
wingnutt's Avatar
I concur with DR. Carbon
"03 RC"
and a new litter
I should REALLY wear a condum
wingnutt is offline
post #155 of 239 (permalink) Old 04-10-2012, 04:23 PM
JBs_SP3's Avatar
So what keeps the coolant inside your motor circulating after you shut it off? Davies Craig make some nice thermo controlled, programmable electric water pumps that will cut in to prevent heat soak after shut down if they're hard wired. But for most of us with standard mechanical water pumps cutting the motor cuts the coolant flow regardless of whether it's at the end of a ride or at the lights. Is shutting the motor off to fill up with gas and then starting it again bad for it? Probably.
JBs_SP3 is offline
post #156 of 239 (permalink) Old 04-11-2012, 02:52 AM
Dr. Carbon
20_RC51_00's Avatar
right but you don't fill up at every light... or stop and go... so it's harm in the relative sense i suppose. not ideal but not going to kill you whenever you fill up
what I do at the track is cool down lap and also let the bike run a bit before thurnign off. I also kill the engine but let the fans run and then either to keep the circulation going I hitting the kill swithc and cranking the engine a few times periodically or actually let it start back up and then kill again, just to prevent the stasis of coolant and vapor blanket next to the cylinder...
post #157 of 239 (permalink) Old 04-11-2012, 08:13 AM
JBs_SP3's Avatar
I think we're on the same page. The ideal for either track or street would have to be proper warm up and maintaining the most stable operating temperatures possible, though obviously maintaining stable temperatures is easier on the track than the road. Your cool down regimen is impressive.
So to qualify my original post I don't shut the motor off at every light and I don't shut it off if it's overheating. When I designed the Thermae rads I could not find a way to accommodate a 5" SPAL fan which is a shame because think one of these would solve the problem of stabilising temperatures in stop and go traffic even for modified motors such as mine. The 4" SPALs are a compromise but they're all that'll fit in there ... for now.
When I first fitted my front mounts the motor was not yet broken in so I ran it without a thermostat anticipating high temperatures. Now the motor's broken in I think I'll re-install the thermostat because running on the road without it the coolant temperatures can swing by as much as 30C - 40C between cruising and stationery. That may not be bad for the motor but I'd rather it was more stable all the same and I can't be arsed messing around with shrouds or tape to block airflow to the rads on a street bike.
An alternative to the OEM thermostat and fan thermo switch would be the Davies Craig system I mentioned, I haven't seen anyone adapt these for an RC51 but I've seen them used on other bikes, pretty trick:
Electric Booster Pump 25 (EBP25) (Pump Only) - PART No: 9105
EWP & FAN DIGITAL CONTROLLER 12V - PART No: 8020
JBs_SP3 is offline
post #158 of 239 (permalink) Old 04-11-2012, 10:04 AM
will be keen to pick up a set when they are ready again!
simonkobe is offline
post #159 of 239 (permalink) Old 04-11-2012, 11:57 AM
Dr. Carbon
20_RC51_00's Avatar
maybe running evans coolant could be beneficia. the responses are that you run a touch hotter but swing less, also it's pressureless.
post #160 of 239 (permalink) Old 04-11-2012, 03:32 PM
^bingo. I have always thought about it
Dobermans with Distinction
5.4 speedster is offline
