front mount ecu - Speedzilla Motorcycle Message Forums
post #1 of 56 (permalink) Old 01-21-2009, 07:12 PM Thread Starter
vanessa's Avatar
front mount ecu
any issues regarding heat when moving ecu forward onto frame spar?
TIA
vanessa is offline
post #2 of 56 (permalink) Old 01-22-2009, 01:26 AM
kewjr's Avatar
Send a message via Yahoo to kewjr
never heard of anybody doing that? but there is also alot on here i miss. seems like it would get soaked with heat the most, in its current location anyway.
kewjr is offline
post #3 of 56 (permalink) Old 01-22-2009, 11:53 PM
WSMC #51, CVRA #51
dstewart's Avatar
TIA
So far, nope.
dstewart is offline
post #4 of 56 (permalink) Old 01-23-2009, 12:14 AM
Big Thymer
bensexcessbikes's Avatar
Originally Posted by dstewart View Post
So far, nope.
I've moved ecus to other places on bikes b4 w/o problems... can't imagine RCs are any different.
Dstewart should know tho... chk out the above link to build...
bensexcessbikes is offline
post #5 of 56 (permalink) Old 01-23-2009, 02:24 PM
I'm an Alcoholic... YAY!!
heavyzee's Avatar
Send a message via AIM to heavyzee Send a message via Yahoo to heavyzee
no problem....
heavyzee is offline
post #6 of 56 (permalink) Old 01-23-2009, 06:32 PM Thread Starter
vanessa's Avatar
thanks,i am on with it at the moment,got the loom in bits,just about sorted,just need to knock up some brackets to mount it all.
might post some pics if i can.
vanessa is offline
post #7 of 56 (permalink) Old 01-24-2009, 04:43 PM
WSMC #51, CVRA #51
dstewart's Avatar
Please do. I love pics.
dstewart is offline
post #8 of 56 (permalink) Old 01-24-2009, 08:52 PM Thread Starter
vanessa's Avatar
lets see if this works
vanessa is offline
post #9 of 56 (permalink) Old 01-24-2009, 09:36 PM Thread Starter
vanessa's Avatar
hey it worked,done a bit more today,pulled the loom apart and decided where every things going.haven't cut the loom as such,just moved it about and think it will be fine.made templates for a couple of brackets and did a lot of head scratching and smoking.thats my pals bike in the background.oh ye,i'm putting the sp2 arm in at last!
vanessa is offline
post #10 of 56 (permalink) Old 01-24-2009, 10:34 PM
origin8or's Avatar
More pics, more pics! Especially the bike in the background. Sweet looking set up you have there.
01 Rc51
What's going on in the garage
origin8or is offline
post #11 of 56 (permalink) Old 01-24-2009, 11:00 PM Thread Starter
vanessa's Avatar
the bike at the back sucks!
vanessa is offline
post #12 of 56 (permalink) Old 01-25-2009, 12:10 AM
ajonty's Avatar
ajonty is offline
post #13 of 56 (permalink) Old 01-25-2009, 12:32 AM
ajonty's Avatar
The Bizzness
MEANER THAN A JUNKYARD DOG
THE
Honda VTR SP1 2000 model
oz gold racing wheels
oz 90 degree valve stems
gold gilles rear sets
gold gilles vario clipons
front pro lite race uk discs
wavey race rear disc
ohlins fg43 r+t forks
penske triple clicker rear shock 8987 series
gold crg shorty levers
braided brake and clutch lines x4
scott rear under slung caliper mounting
sp2 rear swing arm with alloy sleeve
sp2 62mm throttle bodies/12 nozzle injectors
power commander 3 usb
power commander quick shifter
iridium screen
full hrc akrapovic titanium high level exhaust {rare}
akrapovic titanium 50mm straight though race silencers
akrapovic carbon fiber 50mm straight though race silencers
honda hrc brake resevoirs front + rear
probolt titanium axle nut rear
probolt red alloy sprocket nuts x6
pairs system removed
flapper valve system removed
thousten carbon fiber race snorkel
thousten carbon fiber 23 liter air box
gold alloy fairing bolts
gold alloy fuel cap
pyramid red under tray
led rear lights
full hrc castrol honda fairing colin edwards rep {dream machine}
scotts steering damper gold
sp2 oil cooler + alloy mounting brackets
flush front mount indicators
yoyodyne slipper clutch
gold alloy billeted clutch cover rc51
alloy clutch hyperplates
bosch ytz7s mini race battery conversion
side fairing radiator fins
gold renthal 520 chain+sprocket conversion 14/42
gold 520 ek z ring racing chain
probolt red alloy paddock stand bobbins
nicky hayden front sprocket cover mod
[email protected] swing arm shark fin
[email protected] exhaust protectors x2
red pro grips
jim ahlmans speedo healer
moriwaki lower suspension link
carbon fiber heal guards x2
akrapovic carbon fiber exhaust straps x2
probolt gold alloy exhaust strap bolts/nuts
front fenda extenda
gold mesh front v piece cover
black suede seat cover
black foam seat bump stop
sp2 alloy upper fairing brace
brembo rear twin pot caliper
probolt gold alloy screen bolts
red alloy brake/clutch banjo bolts x4
magnetic sump plug
probolt red alloy suspension linkage nuts
carmo 11000rpm ecu rev limiter
motrax gold bar end weights
pyramid red sp2 rear hugger
honda cbr inline coil sticks x2
datatool alarm cat 1
battery relocation mod under oil filter
honda hrc over flow bottle
[email protected] front axle crash bobbins
probolt red alloy shocker nuts x2
honda hrc 1/6 fast action throttle
titanium rear brake disc bolts
probolt titanium fork axle pinch bolts
pipercross air filter
probolt titanuim front brake disc bolts x12
kad 6 pot billet gold race calipers
ebc hh sintered front pads
mitchlin power race tyres m2
WAITING TO DO LIST
moriwaki stage 2 cams
weisco high comp pistons 12 to 1
sp2 flowed heads
lightened + balanced con rods
evo-star shifter kit
JONTY
ajonty is offline
post #14 of 56 (permalink) Old 01-25-2009, 12:45 AM Thread Starter
vanessa's Avatar
You Suck!YOU NEED SOME BOLT ONS!
vanessa is offline
post #15 of 56 (permalink) Old 01-25-2009, 01:01 AM Thread Starter
vanessa's Avatar
{dream machine}-MORE LIKE DREAM ON!
JONTY [/quote]
vanessa is offline
post #16 of 56 (permalink) Old 01-25-2009, 01:10 AM
Jonty compliments on the beutiful bike, i was wondering with a stock motor and raising the limiter to 11,000 did you have any problems so far with the bike?
Did you add any HRC springs and retainers to go along with raising the limiter?
Also your kad calipers for the front can you post a link to where to get these calipers?
Once again a beautiful bike!!!
Redstar is offline
post #17 of 56 (permalink) Old 01-25-2009, 01:31 AM
ajonty's Avatar
Hi there REDSTAR and thank you
No engine problems at all both me and Vanessa ride HARD and hit the rev limiter fairly often.
The valve springs are standard also the retainers the calipers are from
WWW.KAD-UK.COM hope this helps
JONTY
ajonty is offline
post #18 of 56 (permalink) Old 01-25-2009, 01:36 AM Thread Starter
vanessa's Avatar
no issues as yet with limiter,standad motor but comes past mine when i hit limiter (194) british miles.i'm running (15-45)-jonty's running(14-42)
vanessa is offline
post #19 of 56 (permalink) Old 01-25-2009, 02:02 AM Thread Starter
vanessa's Avatar
the bike at the back ROCKS!-trust
vanessa is offline
post #20 of 56 (permalink) Old 01-26-2009, 01:50 AM
THE
iridium screen
gold alloy fuel cap
led rear lights
red pro grips
front fenda extenda
magnetic sump plug
WAITING TO DO LIST
sp2 flowed heads
JONTY
YOU GUYS DON'T KNOW WHAT YOUR DOING STIRING UP THE BRITS
top4233 is offline
