Benefits of Clip-Ons and Rear Sets?? - Speedzilla Motorcycle Message Forums
post #1 of 12 (permalink) Old 08-29-2006, 02:54 AM Thread Starter
Rising Member
1RedRider's Avatar
Question Benefits of Clip-Ons and Rear Sets??
What are the benefits of clip-ons and rear sets for street riding?
1RedRider is offline
post #2 of 12 (permalink) Old 08-29-2006, 02:55 AM
Adjustability!
beaugator is offline
post #3 of 12 (permalink) Old 08-29-2006, 04:57 AM
For street riding I would just cut the tabs off the stock clipons and rotate them out a bit so the grips aren't so tucked in. For casual street use and even some spirited riding thats all I'd do. Also the aftermarket clipons have no bar end weights and vibrate more.
Darth is offline
post #4 of 12 (permalink) Old 08-29-2006, 01:54 PM
TOP GUN Instructor
RVTMAVERICK's Avatar
Exclamation Strange Thing...That!
I took off my bar-end weights, just to test that.....I have to say, the strange thing is, my M/C seems SMOOTHER! ......Anyhow, guess what I did, I left them OFF!
Peace Jeff
RVTMAVERICK is offline
post #5 of 12 (permalink) Old 08-29-2006, 02:01 PM
Canadian Ahrrsee Owner
MyRCRocks's Avatar
The biggest benefits I found with rearsets (Sato's) for street riding are the adjustability, and also the improved shifting. The rearsets have taken all of the 'slop and free-play' out of the stock shift mechanism. I'm now on the best shifting Honda that I've ever ridden!
MyRCRocks is offline
post #6 of 12 (permalink) Old 08-29-2006, 02:19 PM
RC51-less Member
Rigor's Avatar
Rearsets: Aftermarket rearsets are not only adjustable, but have better, and replacable parts in the event of a crash. The adjustability is a benefit, as most allow 1" up and 1" back, benefiting taller riders like myself.
Stock foot pegs, generally suck grip-wise, when compared to aftermarket parts. My Vortex pags grip 10x better than the stock ones. Also, their pegs are solid mount, not folding. Helps keep the side of the bike off the ground in a crash, as well.
Clip-ons: Aftermarket clip-ons are good for numerous reasons. They're lighter and in the event of a crash, their "tubes" (where you grab and controls go) are replacable, unlike stock units. They're adjustable as well, since some guys like a higher grip, or might want somthing wider for better control, and less tucked into the bike. If you use them on the street, vibration can be an issue. You can get aftermarket bar-ends for weight, or you can put your own weight in them. I added weight to another aftermarket set, and secured it with silocone. No more vibration than stock.
Rigor is offline
post #7 of 12 (permalink) Old 08-29-2006, 02:33 PM
Anger managment patient
As for the rear sets I personally can't stand stock pegs. One thing is they fold up everytime I twist my foot when setting up for corners. That makes for a feeling of instability. Clip-ons can reduce the wrist cramps.
EvilTwin-05 is offline
post #8 of 12 (permalink) Old 08-29-2006, 02:42 PM
TOP GUN Instructor
Thumbs up Hey Rigor!.....?......
Hey Dave, You wouldn't by any chance, have that part # handy, for the stock-peg replacement for that peg you replaced it with would you?
I can't charge/afford, them there cheappy Sato rear-sets
Peace Jeff
post #9 of 12 (permalink) Old 08-29-2006, 03:06 PM
RC51-less Member
Rigor's Avatar
Peace Jeff
You mean the stock rearsets I modified??
Rigor is offline
post #10 of 12 (permalink) Old 08-29-2006, 03:15 PM
TOP GUN Instructor
Thumbs up That's Different From......
What I've seen?........But yeah, Details baby, it's all in the details.
post #11 of 12 (permalink) Old 08-29-2006, 03:29 PM
RC51-less Member
Rigor's Avatar
Those are stock rearsets, with the peg mounts ground off. I used Lockhart-Phillips replacement pegs, (2 piece) drilled out the mounting stubs, drilled straight through them, added a 1" aluminum spacer, and used a grade 5 bolt to mount them through the rearset.
In the back, where the bolt goes through, I welded a washer on the rear (bolt head) to spread force over a larger portion of the rear of the rearsets.
Everything in the front that got ground was clearcoated and the rear was painted matching silver just for appearence.
Because of the stock casting, the pef mounting can only be raised about 1/2" from stock. If a piece were added to the stock rearsets, (up and rearward) it would work. I was just messing with some parts I already had in the garage......
Rigor is offline
post #12 of 12 (permalink) Old 08-29-2006, 09:43 PM
TOP GUN Instructor
Thumbs up Awesome........Thanks For The Details,....Dave!
You know, it's all in the details!........Thanks again, alittle more involved than what I was hoping for. I've never looked at it, I was thinkingit was just a swap job .....Maybe over the winter, that is, if I ever stop riding this thing! Long enough...
Peace Jeff
