1098 anyone stripping,rebuilding,changine belts on one ?
If there is anyone out there with a 1098 in bits ,would you be kind and measure the diameter of the two belt rollers that adjust the cam belt tension . Diameter for both fixed and movable rollers please .
life is work
For 1st class dyno-tuning ,mapping, custom eproms- and a whole load of other cool stuff www.hypertrick.net
Chris,
As a segway, there are larger diameter rollers available. This in case you can't get the belts to tension correctly. I've heard of a couple people with the loose belt situation.
